No hydraulics Kioti 1914
   / No hydraulics Kioti 1914 #1
stinkypete
Ive cleaned hyd filter and had the pump tested at a hyd repair shop . Pump is ok with just minor normal wear. I checked the suction line no problem there. Took relief valve apart and shimmed behind the spring but no improvement.
Ive turned the directional valve every way possible and nothing. Anything Else? Thanks for your responses .
   / No hydraulics Kioti 1914 #2
I can't assist with the hydraulic problem you're having. Just wondered why you started a separate thread from this one /forums/images/graemlins/crazy.gif It's the same problem, right? It's usually easier to keep all the related messages in one thread.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
