No hydraulics after hose change
   / No hydraulics after hose change #1
cucamelsmd15
Belews Creek, NC
New Holland Workmaster 40
Workmaster 40 and 110TL loader here. The backstory is that I had a burst hose, and two weeping hoses at the crimp connectors. Had three new hoses made and put them on today. I now have no hydraulics. Front or rear, neither work. Looked through the manuals for both, I think the hoses are hooked up correctly, and I am stumped. Help!
   / No hydraulics after hose change #2
I assume you have correct fluid, filled up. You will have to cycle the loader lever up and down repeatedly to get the air out. Was it loader hoses you replaced? Make sure quick connects are fully seated. Did you reuse yours?
Jim
   / No hydraulics after hose change #3
Check the connect order again & make sure the QD's are on properly.
These aren't the quick connect hoses, they're the hoses that run from the valve at the deck to the loader control. They're upstream of the quick connects.
As far as fluid goes, it's at the low line on the dipstick.
   / No hydraulics after hose change #5
Are they air locked? Take the high end off and fill with hydraulic fluid and reattach maybe.
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2803 (A50460)
2803 (A50460)
