No hydraulic
   / No hydraulic #1
jcharden
H
While working it fairly hard my 05 toolcat lost all hydraulics, including steering and dump box.
Prior to this everything seemed normal.
I did get a very occasional belt squeal when I would push it to hard, but not at the time it quit.
I got the box up thinking I needed to start dismantling for a new belt.
But belt is still in tact.
What should I do next?
Jeff
   / No hydraulic #2
Is the belt tensioner spacing set properly? also make sure the tensioner itself is working properly.
   / No hydraulic #3
is the belt loose?
   / No hydraulic
I will get down in there tomorrow and find out
I just know it is spinning, no squealing, absolutely no hydraulic
Thanks Jeff
   / No hydraulic
Well I removed seat and belt cover, got a good look at belt and tensioner, everything seems fine it appears to be tight,, NO squealing,,
Actually seems like it's too quiet .
Could my pump have went out with absolutely no signs?
   / No hydraulic #6
What did you find was the issue? I'm wondering if the OP was looking at the wrong belt. ??
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
AMG M 35A2C drop side 2 1/2 ton 6 x 6 (A50323)
AMG M 35A2C drop...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Friesen 220 Seed Tender (A50514)
Friesen 220 Seed...
2014 Mack CXU 613 Semi (A50514)
2014 Mack CXU 613...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
