No Horn
   / No Horn #1
jel1988
Elliot Lake, ON
2012 Mahindra Max 22, John Deere D120
I purchased a Max 22 TLB last fall it has no horn. Is there a horn kit available? If not how would a hook up an automotive style horn.
   / No Horn #2
Some ideas:
My ranching and logging mentor (RIP) had a simple bicycle horn on his old JD.
There are also several types of 12 volt horn (aoogah) and button kits at your local parts houses; power source to an inline fuse, to a momentary-on button, to the horn, with a good ground ought to do it.
http://www.soundboard.com/sb/Car_Horn_Sounds
If you have an open spot in the plastic shroud under your steering wheel; a hole can be drilled.....
Jeep Front & Rear Differential (A50121)
Jeep Front & Rear...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2007 BMW 750Li Sedan (A50324)
2007 BMW 750Li...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(4) Painter Hoppers (A50121)
(4) Painter...
