No heat in new T590 Bobcat
   / No heat in new T590 Bobcat #1
kimtek
Orleans. Vt
Bobcat T590
Hello all, I have a new 2015 Bobcat Skidsteer t590. Love the machine only thing is in northern VT, I snowblow with it and no (or very little) heat makes it into the fully enclosed cab. AC seems fine as I have run that last fall but this winter no heat called Bobcat tech they came out lifted cab, found too hot to touch pipes running into heat exchanger under the cab but no heat blowing up into the cab. Tech said it was the way it is with Bobcats, is this true? Any suggestions. Thank you!
   / No heat in new T590 Bobcat #2
I wonder if there's a heater core line that has a valve that needs to be opened or an electronic valve that isn't opening
Brett
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
1998 Freightliner FL70 Dump Truck, VIN # 1FV6HLBC6WH951295 (A51572)
1998 Freightliner...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
