No float on my L3400
/ No float on my L3400 #1
Woodland
The other day, the float stopped working on the FEL on my L3400. When I put the control into the float position, it stops moving but the pressure doesn't release. Nothing in the manual says anything about this. Any ideas where to start?
/ No float on my L3400 #2
Does the lever seem to go all the way? Take the cover off the box and look closely at how far the raise-lower valve is actually moving - try pushing directly on the valve stem to see if it will go far enough to release pressure. If it's being blocked it might have water or oil in the bottom cap restricting valve travel. The cap is usually removable (4 srews) Some have reported drilling a tiny hole in the cap to allow any oil or water to drain out. Hope this helps.
Jumper Cables (A64127)
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
(12) sets of Yetter trash wheels, Coal Valley, IL (A65640)
(12) sets of...
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
FORD 4610 TRACTOR (A64277)
FORD 4610 TRACTOR...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
