No Electrical ZD 323
   / No Electrical ZD 323 #1
RTJ49
Kubota BX 25 & DZ 323
Hi All,
After mowing today I parked the mower in the garage. All was well. I decided to move the mower, I stepped on, went to start, lights for start came on, but no starter action when key was turned, dead quiet. I waited to try again.This time no lights on the panel when key turned to on or start. Hour meter is showing hours, but no starter action, sounds at all. The hour meter stays on. I checked the battery for voltage and it's 12.90. So battery seems fine. Any thoughts as to what, or where to look for a problem?
Thanks,
Raymond
   / No Electrical ZD 323 #2
I know it sounds basic, but for the problem to occur that quickly, it almost sounds like either the brake isn't depressed or the steering arms aren't completely out.
Found the problem. Ignition switch plug in had come loose. On further inspection, the plug would not snap connected. The side of the switch was cracked. This allowed plug in to separate easily. Called Messicks and told them about this. I had the new switch here the next day! Awesome service. Sure like the two extra keys. Thanks Neil.
Raymond
   / No Electrical ZD 323 #4
Raymond
Your welcome :)
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
KUBOTA ZD1211 (A53084)
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
