No brake lights or tail lights
   / No brake lights or tail lights #1
rider10099
Oregon
Jinma 204
I have turn signals on my Jinma, but no brake or tail lights. Bulbs are good, and I seem to have power. Is there something I am missing?
John
Who has already cleared an acre of blackberries taller than the 204.
   / No brake lights or tail lights #2
Sounds like the blackberries got back attcha /forums/images/graemlins/grin.gif
   / No brake lights or tail lights #3
Check your brake light switch on the underside of the tractor it probably got pulled loose from the mounting bracket. the switch looks just like the one on the clutch .mine is mounted on the left side.
   / No brake lights or tail lights #4
Check the fuses with an ohm meter.
Thanks for the tip - sure enough that was it - of course there one also one wire pulled from the taillight as well. Much easier to fix something when you know where to look.
John
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
FRONTIER GM1060E LOT IDENTIFIER 50 (A53084)
FRONTIER GM1060E...
2004 FORD E350 MECHANICS TRUCK (A53426)
2004 FORD E350...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2004 Lull 944E-42 Telescopic Forklift (A53117)
2004 Lull 944E-42...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
