Night Blind Kioti
   / Night Blind Kioti #1
I CAN DIG IT
Ashburnham Mass. USA
CK30
My Headlights on my CK30 stopped working. Checked fuses andbulbs all good. Dash lights work, tail lights work too. Everything else fine but headlights. Any Ideas? Thanks.
   / Night Blind Kioti #3
Sounds like a bad switch or bad wire.
   / Night Blind Kioti #5
Ok, does the horn still honk? it is on the same 20 amp fuse as the headlights. the 5 amp headlight fuse feeds the combination switch which in turn feeds the relay coils for both the low beams and the high beams, of course a relay for each. Are both high and low beams inoperative?
   / Night Blind Kioti #6
The high and low beam relays are by the battery on the starboard side of the tractor. I would take some voltage reading starting there.
   / Night Blind Kioti #8
I had a Dodge truck using Silverstar bulbs. One night I go to drive it and no low beams. Checked everything I could think of and then reinstalled the factory bulbs. Worked as normal.. Both bulbs must have burned out at exactly the same moment. Might have been a voltage spike or something similar.
   / Night Blind Kioti #9
The Silverstar are brighter and they are hotter. So they don't last as long.
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
1969 Lincoln Continental Mark III Coupe Collectible Car (A51694)
1969 Lincoln...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
RoGator RG1100C (A53473)
RoGator RG1100C...
