Banjo
Bronze Member
Perhaps this is just the normal setup, but it seems to me that perhaps the cutter bar on my 477 Haybine isn't quite right. It has 30 fixed guards, and the cutter bar has 29 "full size" teeth and one "half size" tooth on the outside (right) end. When the sickle is all the way right the cutter sticks a good way out. On the left end it seems to me that it's "missing" a tooth. I am having problems sometimes with the left end getting plugged with grass at times.
I've attached some pictures of the left and right end at the two extremes of the sickle travel. In this post it shows the left end when the cutter is all the way to the right. It seems to me that it can't be good having the guard "empty" in this position?
Does this seem right? The cutter bar certainly doesn't look like it could be set up any different way.
thanks, Andrew
thanks, Andrew
