NH vs BX vs JD vs MF Quotes
   / NH vs BX vs JD vs MF Quotes #1
BX1
Bronze Member
Houston, Tx.
Kubota BX 1500 and Bolens ST125
I went to several dealers Saturday. Looked at a BX22-1830, Massey2300 and a JD 2210. The TZ was quoted at $11,271 with 60" MMM. The BX 2230 w/ 60" MMM was $10,145 and the BX 1830 was $9,705 with 54" MMM. The JD 2210 was quoted at $13,999 with 62" MMM, FEL and for Saturday only, a box blade. I think the FEL was about $2800-$3000 option for the all the other tractors. All dealers had pros and cons for their units and others. The Massey seems to have rather high hydraulic flow 6.1 gpm vs the NH at 3.9 gpm. The NH guys says the Massey is foaming and burning the hydraulic fluid. The JD and the BX are rated 1 to 2 gpm lower. Not sure what/who to believe. I think I'm at the point where I might just get a large Lawn Tractor and rent equipment when I need. I'm confused....... /forums/images/graemlins/confused.gif
   / NH vs BX vs JD vs MF Quotes #2
BX1 you have every right to be confused.
Let me try to offer a bit of free advice. ALL 4 of the brands are excellent tractors. You will find supporters of each, and really no detractors of any. The Sub-CUT class of tractors are really all pretty well refined and nicely designed. For your choice, let your rear end and your fingers decide what is best. Buy what feels the best for you, but only if it is from a dealer who will support you. All are very capable. I have my personal choice, but I won't bother to share, simply because it is based on my feel for the machine and my feel for the dealer, not because of any logical reason!
   / NH vs BX vs JD vs MF Quotes #3
I have a BX23 and it is a good tractor. I think Bob is right - you pretty much can't go wrong with any of the four tractors you mentioned. There is one thing though that I am going to throw out - if you are thinking about getting a FEL with whichever tractor you purchase you should look at the Deere - it is the only one of the SubCUT tractors that has a quick attach feature on the FEL bucket. This feature will come in very useful if you plan on using forks on the front, attaching a boompole, different bucket types etc.
   / NH vs BX vs JD vs MF Quotes #4
<font color="blue"> The NH guys says the Massey is foaming and burning the hydraulic fluid. </font>
The only thing that is burning is what he is smoking. Most of the specs on the Massey are slightly higher than the competition.
   / NH vs BX vs JD vs MF Quotes #5
<font color="brown">The NH guys says the Massey is foaming and burning the hydraulic fluid. </font>
</font><font color="blue" class="small">( The only thing that is burning is what he is smoking. )</font>
Ahhhhhh.....dealers are always good for cheap entertainment.
Just like Bird's - "thick steel" dealers comment. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( <font color="blue"> The NH guys says the Massey is foaming and burning the hydraulic fluid. </font>
The only thing that is burning is what he is smoking. Most of the specs on the Massey are slightly higher than the competition. )</font>
I did notice that the MF had somewhat higher ratings across the board (flow, PTO HP, etc), and it appeared to achieve those higher ratings at a lower operating engine RPM. I would think that would equate to less stress on the engine and increase life and better fuel economy. Does that make sense? Thanks for the input from all. It is really appreciated.
   / NH vs BX vs JD vs MF Quotes #7
The advice you are getting is sound, I would just interject my personal feelings. I would never purchase anything from a salesman who sells his product by knocking his competition. This is just my personal bias, but I am death on any salesman who bad mouths the competion. You can not go wrong with any of the choices you are looking at. Maybe the place you can go wrong is in dealer choice. Look hard at the dealer who sells you on service, not on the weakness of the competition. Kind of my soap box and all my humble opinion.
   / NH vs BX vs JD vs MF Quotes #8
<font color="blue"> I would never purchase anything from a salesman who sells his product by knocking his competition. </font>
I agree. A GOOD salesperson can sell something on the merits of their own products, not by bringing up the drawbacks of the competition.
   / NH vs BX vs JD vs MF Quotes #9
Information versus Massey, check these things out, do your research.
The New Holland TZDA is a deluxe sub-compact tractor
with 22 and 25 gross engine horsepower. The TZ22DA
has 17 PTO hp while the TZ25DA has 19 PTO hp. The
TZDA has a 2-range hydrostatic transmission, a 3
cylinder diesel engine, standard independent rear and
mid PTO, and 54 or 60 in mid mount mowers are
available. The TZ22DA and TZ25DA are offered with
FWD and optional Sensitrak. The TZ25DA has the most
engine hp and PTO hp in the sub-compact industry.
Massey Ferguson offers one sub-compact tractor, the
GC2300, as a 22.5 gross engine horsepower tractor.
The GC2300 has 18.7 PTO hp. The GC2300 has a 2-
range hydrostatic transmission, a 3 cylinder diesel
engine, standard rear and mid PTO, and a 54 or 60 inch
mid mount mower is available. The GC2300 is offered
only in FWD.
NH Sensitrak FWD Option
Benefits
• Automatically engages FWD when tractive conditions
require increased pulling power and disengages
FWD when extra traction is no longer
required
• Automatic FWD saves grass and turf, saves tires,
increases drive line life and decreases drive line
wrap up
Value
• The ultimate in turf friendly control, Sensitrak is a
New Holland exclusive
• Provides traction when you need it, just “set it and forget it.
Massey tractor
No Sensitrak FWD Option
• Operator must decide when tractive conditions
require the use of FWD. Inevitably, turf will be
damaged. Increased wear and tear on tires and
driveline components.
New Holland Operator Comfort
Benefits
• Mower deck cutting height adjustment is located on
the left hand fender, right at the operator’s fingertips
• Deluxe cushioned seat on an incline/decline plane
for optimum visibility and access to controls
• Safety seat switch can be adjusted for operator’s
weight (from 50 to 300 lbs), ensuring safety for
every operator!
• More spacious operator platform
• Controls are color-coded and embossed with their
function
• 12 volt power socket for a cooler, cell-phone, or any
other 12 volt power requirement
• Cup holder for a beverage. Storage bin for gloves,
cell phone, etc.
Value
• Deluxe platform with controls at the operator’s
fingertips results in less operator fatigue
• Better vision results in greater productivity and safer
operation
• Best in class operator station adjusts to every
operator
• Operator’s station is designed for the novice operator
Massey tractor
Massey Ferguson Operator’s Station
on the floor. This rotary style adjustment knob can
be difficult to adjust and hard to read while the
operator is on the seat.
• Less spacious platform. Controls are not embossed
with their function, making operation
difficult for the novice operator.
• Safety seat switch is not adjustable for weight
• Seat is on a horizontal plane, which equals poor
visibility relative to the TZDA
• 12-volt power socket is not offered
• Cup holder and storage bin are not offered
NH Automotive Style Dash
Benefits
• Large, easy to read display is centered on the dash
• Tachometer is center display
• Indicator lights include a glow plug indicator, battery
charge indicator, and engine oil pressure
• Gauges include a tachometer, fuel gauge, engine
temperature gauge, and an hour meter
Value
• More gauges and indicator lights mean a more
productive operator and a tachometer provides precise measurements.
GC2300 Dash
• Small display readout
• No tachometer, engine temperature gauge, or
glow plug light
• Remember; “You can’t manage what you can’t measure.
New Holland
Two Pedal Hydrostatic Transmission
Benefits
• Forward and reverse pedals are mounted on
separate shafts so the position and operation of
each can be optimized
• Minimizes pedal effort and provides ease of use for
every operator
Value
• Provides the best performance and most convenient
operation
• Allows easy control of speed and direction
Massey Single Pedal Treadle
• Old technology and awkward actuation
• Not as comfortable as a dual pedal hydro, especially for older or novice operators.
Optional Cruise Control
Benefits
• Electronic cruise control is optional, providing extra
comfort and convenience
Value
• When mowing large areas cruise control is ideal.
Remember, 90% of sub-compacts will have a mid
mount mower!
• Cruise control is an affordable option at $150* List
Massey
Cruise Control N/A
• When mowing large areas, the operator will likely
experience discomfort without the convenience of
cruise control. This discomfort may be exacerbated
by the single-pedal treadle.
TZDA Serviceability
Benefits
• Can check oil without raising the hood
• Can gain complete access to the engine after
opening the one piece ABS plastic hood, which lifts
on a gas strut
• Service interval decal
Value
• Convenient service saves time, more productive
• No tools required for routine maintenence
• Proper maintenence leads to longer life
Massey
More panels to open / remove
• Flip-up hood does not provide access to the entire
engine, difficult to access engine and oil filters, oil
dipstick, and other routine service points
New Holland
Dual Element Air Cleaner
Benefits
• Traps dirt and debris better than a single state air
cleaner
Value
• Longer life, better performance, less likely to need be repaired.
Massey
Single Element Air Cleaner
• Does not trap dirt and debris as well as a dual
element air cleaner
• Does not provide as much protection to the engine
NH Fuel Tank Capacity
Benefits
• A 7.9 gal (29.9L) fuel tank capacity is the largest in
Value
• Longer operating time and less idle time
• Allows the operator to easily drain a full 5 gallon
fuel can into the fuel tank, so that the owner will not
have a half-full can of diesel sitting around the home
Massey Ferguson Fuel Tank Capacity
• A 5.5 gal (21.0L) fuel tank means less operating
time before fueling up
• Unless the tractor is running on fumes, it will be
difficult to empty an entire five gallon can into the massey
TZDA Ground Clearance
Benefits
• Without the mower deck, the ground clearance is
9.1”
• With the mower deck, the ground clearance is 6”
Value
• The operator can box blade, roto-till or perform any
number of jobs with the rear 3-PT while leaving the
mid-mount mower attached to the tractor
• Without the mid-mount mower, the TZ has considerably
more ground clearance than the GC2300
which allows the operator to work in more rough areas.
GC2300 Ground Clearance
• The ground clearance w/o the mid-mount mower
is 6.7”, considerably less than the TZ
• The ground clearance with the mid-mount mower
is 5.9”
• Less likely to allow operation where clearance is needed.
New Holland Lighting
Benefits
• Two dual beam halogen headlights
• Two halogen corner worklights
• Turn signals and flashing warning lights
Value
• Four halogen headlights, powered by a 40 amp
alternator, allow the operator to work in the late
evening or early morning hours
• Better lighting equals more productivity and better working conditions.
Massey Ferguson Lighting
• Two front headlights versus four headlights on the
TZ
• Turn sigals and flashing hazard lights
10LA Loader
Benefits
• Curved boom design fits the contours of the tractor
and provides best in class visibility
• Larger torque tube, rifle barreled grease zerks
• Simultaneous raise and curl valve
• Quick-Latch System
Value
• Better visibility equals more productivity and a safer
operator
• Larger torque tube prevents loader from twisting
Massey Ferguson 2350 FEL
• Dog leg boom design
• Most of the stress on the FEL is located at the dog
leg
• Visibility is poor with the dog leg boom design
Small torque tube.
Check out these areas and I think you will find the NH is a nicer overall package. If your just going to do this once, make sure you take a look at the above comparisons.
Jerry
   / NH vs BX vs JD vs MF Quotes #10
Thats a lot of info.....very interesting though !!! /forums/images/graemlins/cool.gif
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
