NH TS135A Tractor Hydraulic Sensor Problems
   / NH TS135A Tractor Hydraulic Sensor Problems #1
balsip
I seem to have a lot of problems with pressure sensors on my 2004 New Holland TS135A tractor with about 2000 hours. I have had the red "STOP" light come on three times this summer and it costs us precious harvest time. Minor part cost but big time production cost. The sensors are hydraulic lube oil pressure sensor and two times on the "main hydraulic filter suction pressure". The last time I had pressure tested with guage and it never went below 40 psi while switch is tripped at pressures below 8-12 psi. No part available for 5 days so I am operating bypassed. Anyone else having similar type sensor problems?
   / NH TS135A Tractor Hydraulic Sensor Problems #2
There are not very many owners of that tractor on here but hopefully RickB will see this thread and try to help you out. You should have put it in the New Holland forum though as it is New Holland specific. Hopefully one of the moderators will move it.
   / NH TS135A Tractor Hydraulic Sensor Problems #3
Ditto with what Robert said, that TS is quite a big unit. You can always post your question on AgTalk Home
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
SET OF (7) JACK STANDS (A53843)
SET OF (7) JACK...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2018 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2018 DRAGON...
