NH TN75 Hydraulic Problem
   / NH TN75 Hydraulic Problem #1
mustangmarty1967
New Holland TN75
The Loader and 3-point hitch do nothing, but the steering and transmission both work fine. Does a New Holland TN75 have just one hydraulic pump that runs everything? Or is there a second hydraulic pump that runs the loader and 3-point separately from the steering and tranny?
   / NH TN75 Hydraulic Problem #2
It uses a steering pump, rear pump on LH side of engine and main hydraulic pump on the front side. May be an air leak on the suction side or broken drive or shaft
So, three hydraulic pumps then? Since the steering and tranny work, which pump should I focus on first? The rear pump on the LH side of the engine or the main pump on the front of the engine?
   / NH TN75 Hydraulic Problem #4
I think you're both confused. The TN series has two pumps, both on the RIGHT side of the motor. The one on the front of the timing cover is hydraulics, the one one the rear (under the injection pump) is steering/transmission circuits. They share a common suction and filter, and each drive off opposite ends of a timing gear Fiat refers to as a PTO gear.
   / NH TN75 Hydraulic Problem #5
Oops, right, left sorry. It is the right front. Two pumps mounted on engine cover
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
1995 Rinker Captiva 190 (A56438)
1995 Rinker...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
