NH TN65 2001 front end trouble
   / NH TN65 2001 front end trouble #1
birdshak
NH TN65 2001
Now the left front wheel drive is going out. The right front went out last spring. 3700 hours on the tractor. $3500 to have repaired. Do any of you have this same problem?
   / NH TN65 2001 front end trouble #2
G'day and :welcome: sorry to hear about your dillema. We service alot of NH gear and we change the final drive oil EVERY time we change the engine oil, we also use 80w90 gear oil instead or the trans oil they reccommend. We find that the service intervals are just too long for such a small quantity of oil with nowhere for the rubbish to go but floating around the final drive. We have been doing this for years and the only one I have had to rebuild is one that was owner maintained and I don't think he ever changed the oil from the first service we did and it saw out some 6500 hrs. Good luck with your repair:thumbsup:.
Jon
   / NH TN65 2001 front end trouble #3
Jon
X2. Doesn't matter what brand or model, front planetaries have too little oil trying to do too big a job with (in most cases) far too long a drain interval. The ones that don't get changed often enough get parts included with the oil changes. TN's are not prone to front planetary problems. TL's do seem to be as they have larger loaders fitted and are stressed more relative to the component sizing.
Thanks for the tips! A little oil is a whole lot cheaper than a trip to the shop.
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
Unused 2025 CFG MX12RX Mini Excavator (A49461)
Unused 2025 CFG...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
