NH TL100 or Kubota M9540
   / NH TL100 or Kubota M9540 #1
thethrill
Mountain Home, AR
Shopping Around
Both with cab, and FEL. It appears by looking at tractordata.com that the TL100 drastically outweighs the M9540 by a few thousand pounds. Use of the tractors will be on our ranch, bush hogging w/JD MX10 and feeding and moving round bales 1000-1300lbs. Off and on Semi trailer. Also a good deal of grapple work. Would like recommendations as to which you prefer and why. Thanks.
   / NH TL100 or Kubota M9540 #2
I have a TL100A , good tractor , heavy and powerful and Comfortable . Only issue in the 3 years I have owned it is a siezed throwout bearing . I had the clutch replaced and it was expensive.
   / NH TL100 or Kubota M9540 #3
The Kubota's are nice but, a bit lightweight for engine/PTO power. For what you want, make sure the tractor has enough weight for good ground engagement and safe lifts off the semi. While I dearly love my Kubota L4600, it is way too lightweight, especially in the rear, for what I need a tractor for. Great for a weekend hobby farmer/rancher but, not really enough tractor for me even on my 40 acres here at the house.
   / NH TL100 or Kubota M9540 #4
If it's a straight TL100 and not a TL100A it's the 3.9 turbo and 24x12 synchro shuttle. Dry clutch only so careful if loader work.
I drove a brand new one, put many hours on it loader work, tillage, haulage etc.
I liked it.
Pickup Truck Bed (A51691)
Pickup Truck Bed...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
8ft Fork Extensions (A50322)
8ft Fork...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
New 12x20 Steel Carport (A50774)
New 12x20 Steel...
