NH TC35D Temperature Double Trouble
   / NH TC35D Temperature Double Trouble #1
willsonlj
I have a NH TC35D and the first problem I ran into was the cold engine syndrome. I installed the shutoff valve in the drain line and the problem disappeared for about 3 weeks. After 3 weeks of bliss the problem reappeared. The only logical cause was an open thermostat. I removed the thermostat today and sure enough it was being held open by a small metal "flapper" valve. I'm not sure what this small metal flapper valve is for but I removed it with a Dremol tool. I reinstalled the thermostat and every thing works fine now. I thought I would pass this along in case anyone else suffered this dual problem with a single symptom.
   / NH TC35D Temperature Double Trouble #2
Willsonlj
Before they figured out the final fix (the valve), my dealership had replaced the thermostat too thinking that was the problem. I guess they pretty regularly remove the little metal "flapper" you mentioned before installing new thermostats - just because of the exact problem you described. Pretty common on the skid steers as well. Glad to here you were able to re-use your old thermostat - I would have never even thought to do that. If that ever happens to me I probably will though. It is one of those minor things you can do yourself in less time than calling the dealer & getting it fixed. Just wondering though - did you re-use the gasket too???
Troy
   / NH TC35D Temperature Double Trouble #3
I think (and my memory is vague-been a long time) the 'flapper valve' you removed is only used to prevent reverse-flow of coolant when you use a lower radiator hose engine heater. (You want the heated coolant to flow thru the block and not the radiator). Removal shouldn't cause any problems.
Steve
Troy,
Yes I did reuse the gasket. It is a thin cork gasket and was in perfect condition. No leaks so far.
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2006 International 4400 LP Ambulance (A50323)
2006 International...
