NH TC30
   / NH TC30 #1
TNMIKE53
West Tennessee
I am considering buying this tractor but would like to know the pros and cons of it. This is the mechanical transmission model and has two wheel drive. I plan to pull a 6 foot finishing mower and maybe buy a tiller to go with it at a later time. It will be used on 5 acres primarily. Also which would be the better tire the Ag or the R3?
I notice a lot of reference to FEL, what is it, and how should it factor in to my decision?
   / NH TC30 #2
</font><font color="blue" class="small">( I notice a lot of reference to FEL, what is it, and how should it factor in to my decision? )</font>
FEL is Front End Loader, one of the handiest items that can be put on a tractor.
If you plan on the FEL now or anytime in the future I highly recommend 4 wheel drive.
   / NH TC30 #3
My TC30 is a 4WD HST model, so I can't reference the 2WD gear model too well. Given what you stated you will be using it for, the 2WD gear model seems adequate, however 4WD actually puts more useable HP to the ground and will actually be better for use with the tiller when you get it. I noticed your question about the FEL, if you are considering one then 4WD is almost a must. You can use one with 2WD but it's use will be quite limited.
You should buy as much tractor as you can afford, don't limited yourself by only considering short term usage. Once you have one you will find a lot more that you want to do with it, and will only be frustrated if the tractor doesn't have the capability to do it. The TC30 is a very capable, economical, and reliable tractor. I have just over 100 Hrs on mine, and am quite satisfied with it. There have only been a few occasions when I wished that I had bought a bigger tractor (I have 7.5 acres), and none where I had wished I had gone the other way.
As far as tires go, it depends on the surface you are working. If you are only doing plowing or mowing in weedy and really wet areas ag tires will do fine, but they will destroy nicer areas like lawns. Turf tires do well on a lawn, but are almost useless (my opinion) when it comes to plowing and working in mud. The best compromise I have found are the R4 (industrial tires), as they have a less aggressive tread than the ag tires, but offer more traction in wet/loamy areas than the turf tires.
There are a LOT of very satisfied TC30 owners on this board. Do a search and you'll find quite a bit of useful information.
Hope this helps,
Kevin
   / NH TC30
Thanks for the feedback Kevin. I agree the TC30 is a good tractor, but it looks as if going with the 2wd may not be the way to go. I was really looking at the TZ24 as it is more inline with dollars budgeted for this purchase, plus I feel it can meet my immediate needs. I only reached a little higher because I thought the TC30 would be a little heartier if I needed it to, while still meeting my basic needs of grass cutting. However, based on feedback I'm fast reconsidering my position.
   / NH TC30 #5
Glad I could offer some help. Good luck in your decision. Don't forget to post some pictures when you get it.
RoGator 844 sprayer (A50490)
RoGator 844...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
John Deere 455G Loader (A48837)
John Deere 455G...
