NH TC30
   / NH TC30 #1
peitc30
Freetown, PE
NH TC30
Greetings,
I'm new to the forum and need a little help with an issue on my TC30. I live on PEI Canada, it's cold brr. I had my tractor parked outside for a few hours after blowing snow etc in cold temps -25C (-13F) with windchill. This is a 2007 and never had a HST problem. However when starting it later that day HST oil leaked out of the left hand-side HST filter. I needed a HST oil change so bought NAPA filters and NEw Holland approved oil. Not cheap. On removing the old filter is was not that tight so thought that this was the issue. However after replacing the filters and oil and started up the tractor, within a minute the HST filter on the left stated leaking again. Temps are around -11C (12F) so my thought is that the old oil is still congealed in the lines or something. I did turn the tractor over to drain the pipes prior to fitting new filters. The new spec oil is much thinner than old oil and is rated for -25C (-13F)
I'm in a jam, storm is on us and need to blow. It's Friday grrr. Please advice from anyone with good knowledge of HST would be appreciated. Thanks in advance. Regards to all.
   / NH TC30 #2
There was a problem with the filters on the HST New Hollands, especially in cold weather. NH modified them but your Wix may not reflect that modification. Best to contact a knowledgeable NH dealer (Messick's in Pa.-google up their website) you will need to give the year and model, seriel no. of your tractor because after a certain year, they factory-issued the correct filter.
BUT was BIG< BIG PROBLEM,
Another potential problem; O ring leaks off the valve, under the right side; do not use NH or auto parts store O rings; best to buy from Caterpillar or other heavy duty,
Hope this helps.
   / NH TC30 #3
Sorry, meant NAPA not Wix filters.............
   / NH TC30
Much appreciated. I think I will wait for -24C to drop to +9C on Tuesday and then give her a whirl. I used same filters I am using now for 4 years, no problems. I do believe it's the cold, well I hope so. Best for 2014 and thanks again.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2018 FORD F-150 XL (A50854)
2018 FORD F-150 XL...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
