Nh tc 40 d not starting
   / Nh tc 40 d not starting #1
hoot1293
Have a 2002 nh tc 40 d that turns over and over and will not start. I changed the solenoid and checked the voltage to the solenoid . It was 12 volts. The tractor started one time and then it would not start. I checked the voltage and didn't get 12 volts. I was told to check fuel shutoff relay. Does anyone have any other suggestions in case this does not work? I have checked all the fuses and they are good.
Thanks for the help. I found that the seat safety switch was bad. Once fixing it the tractor runs like new.
New Long Forks (A53002)
New Long Forks...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
PIPE TRAILER (HOMEMADE NON TITLED) 28FT (A52472)
PIPE TRAILER...
