NH TC 30 Assistance
   / NH TC 30 Assistance #1
Don Hale
South Carolina
New Holland tc 30
I have just bought a NH 757C Backhoe attacnement for my 2003 TC 30, I am needing assistance on mounting instruction as the brackets to mount to tractor is where the front end loader is bolted. Also the person I bought it from had a newer tc 30 where do I tap into the rear hydraulics The place it mentions in the Operator manual does not exist on my tractor
Thanks for you patience with a relatively new tractor owner:confused:
   / NH TC 30 Assistance #2
Welcome to TBN. Sounds like you might have to either: 1.) buy the correct BH mounts for your model/year tractor or 2.) re-fabricate the existing mounts to work with you current loader.
I believe the necessary hydraulic connection for your BH and tractor is the Power Beyond circuit. You'll need to buy the right hardware for your year/model and install.
A friendly visit with one or more local dealers is a good way to to move forward. You'll need to work with them on the hardware (power beyond) and they can offer you some information to help you determine if fabbing your existing BH mount is a more sensible approach versus buying a new frame.
AKfish
I'd also post your question/questions on the New Holland forum. You might get better results.
   / NH TC 30 Assistance #3
i have the owners manual for an 06 same hoe. might be able to help email me and ill try answer questions..ps new holland says dont leave hoe on all the time it will dammage the block to clutch housing. like it did mine.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2015 DODGE RAM...
