Jrus
Iv got a 2010 NH T1530 hydro and it won't start. I was brush hogging Sunday and when I was done I disengaged PTO and parked tractor. When I came out later it wouldn't start. The starter would click sometimes but it wasn't turning motor. I took it off bench tested it and it ran fine. I put a new battery in and still same thing. I took the starter to the local rebuild shop and $100 bucks later same thing.... Except this time after the first key cycle and click I noticed a buzzing under the dash. I ripped it all apart and the glow plug relay is buzzing like its got a bad ground. Checked the battery ground seemed good. All lights on dash work but it almost seems like there is a short in the system. Has anyone had this problem. I'm starting to think that the ignition went bad. When I try to jump starter the same thing happens like there is a draw on the system but I can't find anything anywhere.... To make it worse its still sitting in the field. Any help would be great thanks for the read.
