NH T1520 ENGINE SEIZED
   / NH T1520 ENGINE SEIZED #1
GLENN AUKER
MILLVILLE
JD 4310
I was just helping my friend who has a 2009 NH T1520 with 900hr. To make a long story short- the remains of one of the main engine bearings is in the bottom of the oil pan. After inquiring how the tractor was being used when it stopped I found out that the owners son had the throttle totally maxed out and stepped into the house for a few minutes. When he came back out it wasn't running! My question is this (since I sold the tractor to him!) should the tractor have been able to sustain this? Thanks in advance for any input. I do understand that it is not a good a good practice to race the engine like that.....
   / NH T1520 ENGINE SEIZED #2
There's more to that story. A guy has to work pretty hard to grenade one of those engines.
I'd want to know a lot more about the owner's maintenance efforts and less about what the son did or didn't do.
   / NH T1520 ENGINE SEIZED #3
I agree with RickB. There is something leading up to the failure. Running at max rpm for a few minutes will not grenade a properly maintained engine.
I bought it at an auction and sold it to this individual in November 2015. I don't have any of the service records, but the machine did appear to be well maintained and likely was garaged. The oil was very clean when I delivered the tractor to him, but when I drained it today it was quite dark.
   / NH T1520 ENGINE SEIZED #5
Saw a TC33 get so hot once it seized. Cooled off, cleaned radiator, changed oil. Started & ran OK; passed a PTO dynamometer test. Still running several years later. ***Not recommended practice.***
   / NH T1520 ENGINE SEIZED #6
Generally speaking, running the tractor at full throttle should not have caused a problem. If you think about it if you run a chop mill off the PTO the tractor would running at about the same speed. As to the oil going black, that is not necessarily an indication of poor maintenance. Many diesel engines can blacken the oil with only a few hours operation.
It could be there was a problem with the bottom end which is why the unit was in an auction. Many years ago I worked in the farm equipment industry and it was common practice to put the "lemon" units to auction because they had a known problem that was to costly to repair.
It was my understanding the tractor came from a farm that was selling out, but you never know at an auction! I will try to research maintenance records with the dealer that sold it originally. I guess I will have to open it up and see what's inside. So far I just dropped the pan a few inches, reached inside and pulled out some nasty looking pieces of bearing. Any good parts sources for these? Used engines? I can't believe it - this was the nicest tractor I've sold yet.
   / NH T1520 ENGINE SEIZED #8
Records aren't gonna matter much. All you need to know is right in front of you and however you decide to deal with it. Good luck to you and the tractor owner. Not many aftermarket engine parts sources for this unit.
   / NH T1520 ENGINE SEIZED #9
I agree, I don't think throttle alone killed it.
I used to leave my 8n on my detached farm for a while while my trailer was being redone. Didn't want to risk a better one unatended ;)
With spring rain, oftentimes thistle and ragweeds, etc, could get 6-7' at the tops. I'd run that 8n with a 5' mower in 1st gear, standing on the runninboards, with the throttle jimmied open with a coat hanger over to the governor. Bid run 15 minutes, then stop to an idle and clean the 3" of fluff off the grill and then keep going.
Max rpm alone didn't kill that tractor. Something else was wrong and high throttle was a catalyst.
   / NH T1520 ENGINE SEIZED #10
Depending on how mechanically inclined you are, replacing the bearings in a engine does not require a total tear-down. Unfortunately you probably have one mangled main and it probably cannot be cleaned up with emery paper which will require removing the crankshaft which will require removing the engine and removal of the front cover and flywheel. Once that is taken care of you can remove the crankshaft and take it to a machine shop to be reground. Labour is the biggest thing on this type of repair.
(INOP) CRAFTSMAN LT1000 RIDE ON LAWNMOWER (A51247)
(INOP) CRAFTSMAN...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
UNUSED RAYTREE RMBD72S-72' DRUM MULCHER (A51248)
UNUSED RAYTREE...
2020 KUBOTA RTV...
Informational Lot - Shipping (A53472)
Informational Lot...
2009 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2009 MAC MFG 53'...
