NH Boomer 50 Rear Hydraulics
   / NH Boomer 50 Rear Hydraulics #1
Steve_S
Bronze Member
Middletown PA
MF GC2300
Hi all. I just sold my Kubota B2301 because I needed a much larger tractor and ended up getting a great deal on a 2011 Boomer 50. My only issue is that it does not have rear accessory hydraulics which I need for some of my implements. My question is: What are your experiences with the various kits and which would you recommend?
   / NH Boomer 50 Rear Hydraulics #2
Don't know if your Boomer is an HST or the 16x16 but have you looked at a stock NH rear remote kit? We have a TC40D & after looking at the options we added the 2nd & 3rd remote kits from NH. They come complete with every part (valves, pre-bent steel lines, brackets, levers, even the quick connects). They are definitely more pricy than other kits or piecing a system together; but the factory kits put everything where it should be.... bolts right on & an easy install.
We went that route because we wanted the levers at the factory locations for a clean install & intuitive function control, everything sits right were it should...
I didn't really look into it but check out NH part - DIA KIT, REAR REMOTE CONTROL VALVE #2 - HST - MT20117326. If I'm reading that kit correctly that is a factory NH 2 Rear remote kit for an HST Boomer 50. Around $1200 - $1300 but includes everything for 2 Rear Remotes to be installed as Factory... Just make sure you double check to see if I was reading it right...
Just an idea to look into....
Below is a pic of how clean the factory kit installed on our TC40D....
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
