prof fate
Platinum Member
- Joined
- May 30, 2018
- Messages
- 684
- Location
- beaver pa
- Tractor
- kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
Would prefer to chat on the phone...
first baler, first time baling..used but told it worked fine. Seems in excellent mechanincal condition. I ran it through a cycle manually the best I could - all seemed good.
Hit the field..noticed the feed tines loaded up and stopped moving..backed up and they moved again. - So the slip clutch is working.
Makes flakes just fine...but didn't tie anything.
I go to look and the twine needles are both broken..plunger hit them. Pricey ouch ($200...)
They are in the retracted posiition (well, the mount is...) - BUT - the knotters are PART way through a cycle and DO NOT MOVE. The shear bolt is intact. The knotter clutch seems to be the issue..or is the brake stuck on? There is a trip arm on the outside of the knotter clutch looks like it should have a spring on it...hole and a tab wit a hole...can't find an image of what it SHOULD look like.
The knotters moved from 'rest' position and stopped...I can't find anything jammed anywhere, but a needle tip was in there (loose)
I got hay in the field needing baled...but don't want to order needles until I know what the issue is and what other part(s) I may need.
PM me and we'll exhange phone numbers if that would work better than 1000 words of typing.
