NH 72" MMM rear discharge
   / NH 72" MMM rear discharge #1
TCBoomer
Platinum Member
CT
New Holland TC24DA
NH 72\" MMM rear discharge
I am seriously considering stepping up to a TC29DA or the 33, since my 21 developed a slight problem. I would also like to step up from my current 60" MMM to the 72". Any chance anyone has used a 72" or know of any issues I should be aware of? I mow 2.5 acreas of mostly flat terrain, but have an area that has about a 25 degree slope.
Thanks...
   / NH 72" MMM rear discharge #2
Re: NH 72\" MMM rear discharge
I wouldn't recommend it for the size tractor you have. I have a 33 and at times I think it struggles keeping up. I don't let my grass get too high and try not to cut when too wet but I can say my brother in-law has a side discharge and it seems to shoot the grass out and go much better than mine.
   / NH 72" MMM rear discharge #3
He wouldn't be using it on his 21. He is looking at upgrading to a 29 or 33. He wouldn't have any problems then - or shouldn't have any more problems then the rest of us have had with our rear discharge MMMs. /forums/images/graemlins/smile.gif
   / NH 72" MMM rear discharge #4
I have a 72" on my TC29D along with the Gator blades which will pull out some of the horsepower and I have no troubles what so ever. I do have to slow down some on my hills but not enough to worry about. I do have some pretty steep hills in which I pretty much won't mow on sideways just up and down.
murph
Like Jim said, The 72" would be for a new 33, not my current 21. I agree about having to babysit the grass if you want a clean, finished cut with the rear discharge. The reason I don't really want the side discharge is the windrows. Is your BIL's a NH MMM and does it leave windrows?
Are your tires loaded?
   / NH 72" MMM rear discharge #7
TC,
My tires are not loaded. Not sure what that would have to do with HP and handling a 72" MMM. My 72" MMM is a side discharge and it does not make windrows anymore. It did until I put a real thick washer under the shoot to hold it up some. Now my grass goes out at least ten feet. But I still wished I had the rear discharge so I can mow up close on both side.
murph washers
The reason I asked was you mentioned you mow some steep hills and I was curious how stable the 29 was without loaded tires, on a hill.
...and you answered it already, in another post. Thanks
   / NH 72" MMM rear discharge #9
Yep your right, the loaded tires would help, but I think I have enought weight for the tractor alone leaving dents. I ended up putting wheel weights on my 21 but did not have to on my 29. I have ballast for when I use my loader for the 3 point hitch.
murph
STORAGE FEES (A52576)
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
