NH 479 Haybine Quesiton
   / NH 479 Haybine Quesiton #1
trailrider1205
Edgerton,KS
Ford 4600
I'm looking at a NH 479 that has a couple spots where you can see the metal on the rollers. The sizes are about a half dollar or so. The haybine has only been used to mow about 80 acres a year for the last 10 years or so. Well maintained.
I will be using it to mow my 5 acre hay field.
Is it worth picking it up for 700? How long would the rollers last? Currently using a sickle mower, but have added clover to my mix. Also would like to gain a day or so in drying.
   / NH 479 Haybine Quesiton #2
Rick B here is the expert on NH equipment...
We have an old 477 that we use yearly and it is still a good old machine...
Our rollers are still in good working order and not worn completely out...
At that price I would think that the condition is somewhat suspect...
Replacing parts on those haybines are expensive if you are talking rollers...
The reason for the price is because he is my friend. I have helped him hay in the past and never had any problems with this machine.
   / NH 479 Haybine Quesiton #4
Is the rubber loose around the holes, or is it still solid? If its still solid, I probably wouldn't worry about it... IIRC, getting the rollers re-covered is $1000-2000 and a LOT of sweat equity. These people: B&D Rollers reportedly do a good job re-covering rollers.
Aaron Z
   / NH 479 Haybine Quesiton #5
For $700 and considering that the rest of it is somewhat of a known quantity, I'd probably risk it. The machine will never be worth a set of new or reconditioned rolls, however. i assume you will be cutting less than the 80 or so acres per year it has recently seen.
   / NH 479 Haybine Quesiton #6
Did not realize such and old post
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
