Sickle Bar NH 451 sickle mower
   / NH 451 sickle mower #1
DK_Farms
South Louisiana
JD 4610 E-hydro 4WD, JD 5525 4WD Cab, JD 4066R
Farmer John is going out of business and has a New Holland 451 sickle mower dirt cheap(less than $400) that he says is 4 or 5 years old. Naturally, he says it's in "great shape" and was unhooked in perfect working condition. I checked with the local NH dealer and the 451 is still a current production model and the 6 ft. sells for $4,695 brand new. I want to go look at it, but I would like to be a little more informed about what I am looking at. Does anyone know of any inherent problems associated with this mower that I should look for? I can judge worn knives, guards, belts, and Pittman arms, but I want to make sure there isn't some "gotcha" with this unit. Thanks
Ken
   / NH 451 sickle mower #2
These mower are pretty much trouble free unless run into trees or over a pile of rocks, at less than 400.00 you should jump on this quickly you will not be disappointed they are a great mower. The only parts we ever sell for these mowers are drive belts and sickle sections, guards, and knife bushings all wear parts.
   / NH 451 sickle mower #3
The mower is worth $750-1,000 just for parts even if it does not work.
   / NH 451 sickle mower #4
The weak place to check for on a 451 NH mower is where the trip arm loop fastens to the mower curved frame at the back end of the trip--Lots of weld repairs in this area--Also check the tag and be sure it says 451 as the 450 looks very similar--Ken Sweet
2008 CAT 287C (A50854)
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
