Mowing NH 450 Sickle Mower on Kubota L3650
   / NH 450 Sickle Mower on Kubota L3650 #1
John3650
just purchased a NH 450 sickle bar mower and not having used one before I am having trouble hooking it up to my Kubota 40hp tractor. I can't seem to get the u shaped piece past the lift arm up rights so to attach it to the tractor. Do I need to adjust them in closer to the tractor to get more clearance for the u shaped piece? It looks like the adjustable top link goes between the two u shaped pieces on the mower and the first one attaches to the tractor. I hope this is making sense.
Is there a better way to do this or am I missing something? Any help would be appreciated.
John
   / NH 450 Sickle Mower on Kubota L3650 #2
It sounds like you are trying to hook it up right. When I had a 451 and a John Deere 4500 cut which I believe to be comparable to your tractor, the center would not hook up right because of other brackets in the way, ect.
I ended up chaining the front together and picking it up with a quick hitch and using hydraulics to raise and lower the arm since it is supposed to raise and lower according to where the 3 pt is-obviously that would not work with my setup. Maybe someone else has the right answer for you but that is what I did.
John
   / NH 450 Sickle Mower on Kubota L3650 #3
John
Hi Johm - welcome to TBN
The New Holland 451's U-shaped frame does interfere with Kubota's lift links. I mounted my 451 on a L3600 by making two short extension pieces for the top link that move the connection point out a couple inches.
Thanks guys for your help. I think we are on the right track now thanks to both of you.
John
GAS BUSTER FOR FLARE SYSTEM (A50854)
GAS BUSTER FOR...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
71066 (A49346)
71066 (A49346)
2012 MACK CHU (PINNACLE) (A50854)
2012 MACK CHU...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
