NH 3415 Problem starting after using PTO
   / NH 3415 Problem starting after using PTO #1
Darroch
Little Rock, ARK
NH 3415
OK. I have read some similar issues here but have not found a solution yet :confused:
Whenever I have previously engaged the PTO (i.e. bush hogging) and park the tractor for a bit (lunchbreak, etc.) it will not start - not even turn over or any noise from starter. I can "jiggle" the PTO engagement handle while simulaneously turjing the key and it will sometimes fire right up..........but often it will not. Now if I let it sit a day (or 3) and try the juggling/starting again it will fire right up. This only occurrs when I have used the PTO.
I know there must be some sort of switch and/or contact that is responsible, but which/where/how to replace and/or disable it.
   / NH 3415 Problem starting after using PTO #2
pto safety switch is going out or is out of adjustment i would guess
Yes, I understand that the PTO safety switch is going out. What I need to know is where it is located so that I can change it. I have followed the lever down and over to where it inserts into the main body of the tracor, a small "box". Any problems with removing the bolts to look for it there?
Toro Mower (A50324)
Toro Mower (A50324)
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
