Quick Hitches NH 275 square baler problems
   / NH 275 square baler problems #1
pusto3
Moulton, Tx
NH 3930 IH B
My NH 275 square baler has new pickup fingers on it, but now the pickup cage won't rotate when I rotate the flywheel. The plunger, feeder carriage, knotter, etc all work, but the pickup cage just sits still. I can see the shaft in the pickup drive over running clutch is not moving when I rotate the flywheel.
I suspect that when I was changing the pickup fingers out, since I had to rotate the cage to install the new ones, that I might have damaged the pins in the pickup drive over-running clutch. The manual says to service the pickup drive over-running clutch once a year, so this leads me to believe that I could have knocked one of the little pins loose, being without oil, perhaps.
All I can think to do is to remove the clutch assembly, and have a look at it. Any ideas? Many thanks.
   / NH 275 square baler problems #2
Drive pin or shear pin missing. Or (obviously- like you say) clutch malfunction.
John Deer 625F Grain Platform (A50514)
John Deer 625F...
2011 Mack CXU613 Truck (A52128)
2011 Mack CXU613...
Pallet Fees (A50774)
2016 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
