NH 269 still no Knot tying Knots WITH Sisal
   / NH 269 still no Knot tying Knots WITH Sisal #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I'm a stubborn person and believe I can make the old baler tie with sisal. All my "advisers" only use poly twine. Now after about 2 months of misery. I'm down to twine plate adjustment twine holder spring tension and bale tension adjustments. I'm seeing the twine plate 5/16" not staying put or either they just stop in different places (small differences). I got like six bales in a row to tie (whoopee) then rounded the corner and started down a new row and no ties on one side, then, no ties on either sides. I've the Hydroformatic valve showing no pressure as I feel the bales are fairly tight, but, tonite I will try about a 100 psi and see if more bale tension will help along with a little more twine holder tension. The book gives the same symptoms to to much tension as well as too little tension. The other is with the proper number of links in the knotter drive chain I have no adjustment left. It requires 151 full links 1 connector link and 1 half link ( this comes from NH Dealer) no reference in the op manual as to number of links. The chain has to be run tight and as of now I've a little slop in the chain. bjr
   / NH 269 still no Knot tying Knots WITH Sisal #2
I have an old NH 68 and use sisal. I doubt that the tying mechanism on your baler is exactly the same, but I always have tying problems when I try to make the bales too tight.
I finally gave up and went and bought 2 rolls of Poly from the New Holland Dealer and finally, and, it finally started tying knots. I had to get my hay off the field. I'm not sure if maybe there could be different twine holder plates for the Sisal? The local Dealer just doesn't know much about the small square older balers and not much interest them. If there is any one out there with Sisal twine knowledge on older New Holland balers let me know if there is different parts on the knotters for them. bjr
   / NH 269 still no Knot tying Knots WITH Sisal #4
The sisal twine has become very inconsistent in diameter causing many of the issues with knotters.
Clark CC525MB (A47384)
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
John Deere 652R (A50121)
John Deere 652R...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2015 Freightliner M2 106 26FT Box Truck (A50323)
2015 Freightliner...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
