NH 2120 Hydraulic problems
   / NH 2120 Hydraulic problems #1
woodman2120
Lebanon, CT
NH2120
I am having problems with the hydraulics on my NH 2120 tractor.
I use the tractor for my firewood business; so I have a bucket and Farmi Winch on the tractor.
Recently, I have been experiencing problems when the winch is lifted. When the winch is fully lifted the tractor still labors as thought it is still lifting the winch.
I have changed the filter, which did not fix the problem. Someone suggested the relief valve in the pump.
What I want to know is there a way to replace the valve without buying a new pump? I have been searching online for a diagram of the pump to get a part number for the valve and haven't found anything that helps.
I am also wondering if there is a repair kit for the pump?
   / NH 2120 Hydraulic problems #2
Drop the winch slightly from full lift and see if the pump unloads. If so, you probably have a lift control valve problem, maybe the unload valve. Some settings adjustments might help. I just operate my 3ph lift slightly below full lift to avoid the problem.
   / NH 2120 Hydraulic problems #3
Look and see if you have a feedback linkage and if you do just adjust it. I can't help with a picture for the NH tractor, maybe someone with a NH can post one for you.
Thanks for the help. Going to work with it at slightly below full lift.
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
KMC 5610 (A53084)
KMC 5610 (A53084)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
