Hi all, Anyone know what is involved in replacing the seal in this bugger. Does the shaft just slide out to get to the seal or is it more involved. The 1520 and 1320 should be the same if you own one of them. Thanks up front for any info.
Usually the shaft just slides out. There is a flange on the back with 4 bolts. All you need to do is remove that cover to get to the seal, but you might need to pull the shaft with it as well since it also probably has the bearing as part of the cap. You will need the seal and the gasket for the round cover.
Go to Messicks and look up the parts diagram, it will show you what you need.
