Buying Advice NH 1500/1700 Potential Buyers Beware
   / NH 1500/1700 Potential Buyers Beware #1
old1500
Southern US
Ford 1500
I had owned/operated Japanese compact tractors for years, but recently sprung for a Ford 1500. The 1500 has advantages over some of the others and for the most part, I feel like the 1500/1700 series is much better built....but they have a few very weak links.
The steering gear housing assembly is very week. Obviously, originally no bushing/bearing was installed in the case at the output shaft and this point wears to the degree that a round of steering loss can be expected over time due to sector arm slack/play. Another weak point is the front axle-to-frame attachment. The front axle is connected to the frame via a pivot shaft welded onto the frame and cradled in cups with drive bushings on both sides. If overlooked...these will also wear and result in yet another few inches of steering loss. Another weak area is the method in which the battery is mounted just if front of the radiator. If the tray is not maintained (as in corrodes and comes apart) and the battery gets loose....the first thing it will beat-on is the face of the radiator. Other compact tractors use similar mounting methods, but there are some frame members/radiator mounts between the battery and the radiator. The water-pump is yet another weakness. The shaft is rather long, resulting in great belt stress being applied out on the pulley-end, which eventually wears out the bearing.
I believe the Ford/NH 1500 is a much stronger tractor in may ways as compared to some of the others and if these points are serviced on a regular basis, may not offer any problems, but can be expensive to fix. If I were thinking on the purchase of another one...I would pay close attention to these items just mentioned. You can very quickly turn a great deal on a $1500 tractor into a $3000 proposition to put it back in working order.
I am thrilled with my little 1500, but I would never have paid what I did for it had I realized it was going to cost as much to fix is as it did to buy it. As was....it had a steering system with a "mind of it's own."
I am not whining....I like the little monster and it's generally built like a tank. I am just making a few points that I as a new owner have observed that should be considered in pricing/purchasing this model tractor.
   / NH 1500/1700 Potential Buyers Beware #2
When things are new they are all great! As age and use come into play the weak links will stand out more.
Parts, rebuildability and reliability only show up after a few thousand hours on the well built units. Those that are lacking will come into play sooner for some and later for others depending on the type of use.
I totally agree art. A little grease here-n-there and now-n-then will solve lots of problems. I think on this one I have....somebody greased what they could see without bending over, reading a manual or looking for hidden grease fittings. This little devil is as tight as a drum in the engine and drive-train and there is no telling how many hours it actually has on it. The tractor itself is a testimonial to it's durability. The hour meter had stopped at 0404, so I know that's worthless. Luckily....all I have it for is to play with and it should outlast me. Many of the folks on this forum have helped me out, for which I am greatly appreciative.
   / NH 1500/1700 Potential Buyers Beware #4
imho, no bushings in the steering box was a bit of a bone headed move.. but they probably built that scut on a 'throw away' schedule, figuring by the time major components wore, they could just sell you another tractor vs 8$ of bushings.. :)
soundguy
I agree soundguy.
When I replaced those bushings in the pivot shafts on the front end, it took out a good bit of my mind-of-its-on-steering. The back side had gone so long without grease that the shaft itself was a bit worn. The bushing (what was left of it) was as thin as a razor-blade in some spots. Anybody that has one of these little buggers....DO NOT NEED TO OVERLOOK GREASING THOSE VERY FREQUENTLY. The steering box is a fall/winter project.
Club Car Electric Golf Cart (A48082)
Club Car Electric...
1984 Trailmobile Enclosed Van Trailer (A50397)
1984 Trailmobile...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2021 Ford F-150...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A48836)
2015 International...
2014 VOLVO VNM DAY CAB (A50046)
2014 VOLVO VNM DAY...
2024 KUBOTA KX080-5 EXCAVATOR (A50458)
2024 KUBOTA...
