Buying Advice Next Tractor Advice
   / Next Tractor Advice #1
blainesdad
Elizabethton, TN
2155 John Deere , 2550 John Deere MFWD with 175 loader, John Deere 5310 MFWD with 541 loader
First of all, let me say that I just joined this site and think it is really cool. Have been a member of several different forums for a while now(Diesel trucks, softball, etc)but just found this one and love it.
I am looking for some advice. I am considering buying/trading for a Newer 4x4tractor with a frontloader on it. Here is my background, have always used/owned John Deere's. Had an 820, 2040, 1530, and now a 2155. I love all of the 3 cylinder older diesel's and my Dad can fix about anything on them(HUGE PLUS). My question is what kind of newer tractor will offer similiar performance and not be such a huge change mechanically? I have looked at several different ones online and have decided I would like to be in the 5200 series range. 5200, 5203, 5205, 5210....etc. I don't use the tractor a great lot, but would love having a 4x4 for winter use. During the summer it is mostly bushhogging and running a smaller hay operation(25-45 acres). What are some of the pro's/con's of the tractors that I am considering and keep in mind that I do have a limited budget as well(sucks to be young and poor..lol).
Any and all advice will be greatly appreciated.
Steve
   / Next Tractor Advice #2
Welcome to TBN, Steve. The line-up of 5000 series tractors that you mentioned are very solid, bullet-proof tractors -- and pretty straight forward to repair and maintain.
That said; there are some differences in the machines. Importantly, PTO horsepower and transmissions.
Shuttle trannys vs standard shift. Collar shift vs synchro. And some have 2 ranges vs 3 ranges in others.
What do you need? How big a baler, mower, conditioner, etc. are you using or planning to use?
We can all respond better if you give us a little more info to go on.
AKfish
AKfish
Well I typically use a New Holland Square Baler(273 Model) and I use either a 7 ft sickle mower or 7 ft disc mower to cut with. The 2155 that I have right now is about the perfect size for what I do. I would really like to find a 4wd 2155 with a loader, but you have about as much luck with that as find the fountain of youth. I am not real familiar with the different types of transmissions that you are referring to. Of course my 2155 has 8 forward and 4 reverses...so whatever I get if it has a tranny similiar to that I would be tickled to death. Thanks for your input.
   / Next Tractor Advice #4
OK, you've got a collar-shift tranny without the rabbit/turtle (overdrive) lever on the left side of the gauge panel.
Great tractor - and you've got a very reliable baler to go with it! Mentioned a 7ft disc mower - is that a bush hog type rotary cutter - or a hay type mower with the individual cutter "turtles" ? They can require some serious pto power in heavy hay conditions!
I'd guess that you'd want to stay in the 50-60hp @ the pto range. The more current models that are most comparable to your current tractor would be the 5105-5205 machines. However, those models were replaced with the 5103-5203 in 2007 (I think). The 05 series were mostly USA built and the 03 machines are built in India.
Different transmissions - 05 - has the 4 speed, 2 range tranny (like your 2155) and the 03's have the 3 speed, 3 range transmission.
Here's a few places I've used in the past to review prices, features and locations for used equipment.
Used Tractors and Farm Machinery from Fastline
Used Farm & Agricultural Equipment - John Deere MachineFinder
Used Tractors at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, Case IH, New Holland, Agco, Caterpillar.
Also, here's a great reference site to compare the differences between tractor models;
TractorData.com - information on all makes and models of tractors
Good luck.
AKfish
Good luck.
AKfish
Thanks for the info. I utilize all of those sights on a regular basis. Just looking for some real world answers ya know. The disc mower is hay type machine. I have 6 ft john deere bush hog machine that I use as well on occasion. I have pretty much decided that if I go with another Deere it will either be a 4x4 2155 or a 5300, 5310 series. I am also considering a Kubota m6800(little bigger unit) and a New Holland(Ford) 3930 that is for sale locally for a pretty good deal. The only thing that is holding me up on the 3930 tractor is the fact that it is a little smaller HP wise. Rated at like 47-51HP.
   / Next Tractor Advice #6
I have a 1530 and decided on replacing it with a 2155. It took seemingly forever to find a suitable 2155 in the right price range but it was well worth. My Brother in law has a Ford 3930 that I have used sometimes thru the years. I wouldn't trade either one of my JDs for 2 of the 3930. I considered a new JD and a new Kubota but decided I would be much happier waiting to find the 2155.
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
New Idea Pull Type Hay Rake (A50515)
New Idea Pull Type...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
