Newly rebuilt Kubota B6100 with mystery engine oil leak
   / Newly rebuilt Kubota B6100 with mystery engine oil leak #1
SilverLakeFab
Bronze Member
Concord, NH
Kubota B6100D & Honda RT5000
I recently completed the engine rebuild on my 1978 Kubota B6100 and have just barely been able to put it to work with snow removal (we've been getting pounded in the North East). It takes me a couple hours to clean my driveway with this little machine and this morning the tractor started draining engine oil. I know that the machine was running pretty hot because the radiator overflow tube had a little bit of coolant in it. The weird thing is where the oil was coming from. The oil was draining off the bottom of the starter, and not just dripping, but 3-4 ounces must have drained out, so it was a solid stream for a few seconds. I checked the oil level is where is should be and not too high. Honestly, I don't know where this oil is escaping from. Does anyone have any suggestions or recommendations as to where to check? I've attached a picture of where the oil was leaking, or rather dripping off the machine. I'll inspect again and report back, but this is a weird one.
   / Newly rebuilt Kubota B6100 with mystery engine oil leak #2
G'day pull the starter off and check for oil in the bellhousing if so possible rear main failure or maybe welch plug on the back of the camshaft
Jon
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2003 John Deere 270 Series II Compact Wheel Loader Skid Steer (A50322)
2003 John Deere...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
Ficklin 4500 Gravity Wagon (A50774)
Ficklin 4500...
