Ok, I'm afraid I have to disagree with dfkrug and any of you guys that are comparing apple to oranges.
Hoe attachments are comparable by digging depth primarily. Force
specs quoted in brochures do not always apply to the tractor you are
using. For example, many of the budget JDs (x70) supply only 2000-2100psi
with their implement pumps, while the 955, 4310, etc supply about 2500psi.
If the main relief valve on the hoes were set at 2100psi or lower, then
you can compare the forces fairly, but brochures do not usually state the
test conditions. It is also true that some 6.5-ft class hoes can exert
some greater forces than some 7.5-ft class hoes, due to shorter booms/
dippers and similar cylinder sizes. Digging depth is still the key spec for
most buyers. Because specs in the brochures are of questionable value,
I think it is more useful to compare hoe forces of the same class by
looking at cylinder size and dipper stick moment arm ratios. I also look at
how the hoe is constructed (gussets? pin size?) to see how they compare
for strength. The RVs are usually adjustable.
The JD Configurator has replaced the 447 and 448 hoe listings for the
tractors they were designed for, with the 375 and 485. This implies that
the former units are no longer available, and have been updated with the
new designs. Also, the 7 and 8B are still available, but not the 47 or 48.
