Newbie with Yanmar 1300D
   / Newbie with Yanmar 1300D #1
clownshoe
vt
Yanmar 1300D
Hello,
My name is Aaron,and I live in VT. As of Friday evening at 6:01 pm
I became the proud owner of a Yanmar 1300D. This being my first Tractor I thought it wise to spend a few hours browsing the threads to avoid the dumb newbie questions. The 1300D needs some front end work. According to the previous owner the right front bevel gears are worn(teeth missing). Anyone have any BTDT info on this problem? I've allready gotten some quotes on replacement parts,and it looks like I can fix it for around $400.
Thank you for your help!
Aaron
   / Newbie with Yanmar 1300D #2
Hello Aaron and welcome to TBN.
That sounds reasonable for the parts you need. I have owned two 1300D Yanmars....well I still own one. For it's size and weight it is easy to underestimate the potential power. I have used it to pull bigger tractors stuck in the mud that were two wheel drive.
Since you are aware of the front end problems with that model then I believe there is nothing else to be too worried about. Parts seem to be more available now then when I was searching for them.
I might mention that it is a thermosiphon model (no water pump) and that coolant should be diluted 75% with water unless your in a sub-freezing climate.
Any future problems or questions and you will find lots of help right here on TBN. Good Luck and regards, Mark
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2015 DODGE RAM...
2005 International 4300 Heil S/A Dump Truck (A50323)
2005 International...
Land Honor Skid Steer 3 pt Hitch Adapter (A50515)
Land Honor Skid...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
