Newbie with acronym question
   / Newbie with acronym question #1
amigo
Iowa, U.S.
Cub Cadet HDS 2165
I am in process of purchasing an HDS 2165 Cub Cadet. I would like to know what HDS stands for. I would also appreciate any good sources of how this tractor compares with others and features that are standard. Thank you for any info.
   / Newbie with acronym question #2
Pretty sure it's not Home Depot Special /forums/images/graemlins/tongue.gif. Maybe HyDroStatic or Heavy Duty Service? Dunno /forums/images/graemlins/confused.gif I'm curious to what it means though!
G/luck
Joel
   / Newbie with acronym question #3
Pretty close JT...There are 2 series in the 2000. AGS (Auto Gear System) & HDS (Hydro Drive System). The 2165 uses the 16 hp Briggs Vanguard OHV (V twin). Possibly still manuf. by IH and not MTD. Not sure. Been around for awhile and have a high rating.
   / Newbie with acronym question #4
</font><font color="blue" class="small">( ....AGS (Auto Gear System) & HDS (Hydro Drive System).... )</font>
Ah-Ha! Thanks 1OD.
Joel
   / Newbie with acronym question #5
They really aren't that much different from what they are today. The 2165 has the same heavy duty hydrostatic, so its able to pull very well. The auto-gear was their manual transmission with auto clutch I believe. A very dependable heavy duty unit.
You will find that pretty much its going to compare to today's CC 2180 and you'll also find that aside from graphics, its essentially the same. The Vanguard is a jem of an engine, very strong yet quiet. Yours may have the 42" deck which hasn't changed, should also have the quick release feature. Hope that helped. /forums/images/graemlins/grin.gif
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
Tires (A47384)
Tires (A47384)
John Deere 2355 (A50120)
John Deere 2355...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
