Newbie with a post hole digger- tractor mounted.
   / Newbie with a post hole digger- tractor mounted. #1
Cormac
Park Springs, Texas
Any guidance? I will be doing corner posts with 4.5" OD pipe. Is 9" auger OK or should I also invest in a 12"? North Texas sandy soil will be involved?
   / Newbie with a post hole digger- tractor mounted. #2
9" should be good, as long as you can keep the sand from falling back into the hole before the post is in there. I like to keep as little soil disturbed as possible when setting posts. Backfilling and tamping soil around the post or pouring concrete?
   / Newbie with a post hole digger- tractor mounted. #4
I would go with a 12" auger..
4.5" pipe, 9" hole, 2.25" of cement around the pipe.
Not a lot of strength in such thin cement..
A big Pain to place the cement in the hole..
   / Newbie with a post hole digger- tractor mounted. #5
If the sand falls back into the post hole keep some water handy and wet the hole as it is being dug. Works great for loose sand. I like the larger hole but 9 inch should be fine for most applications.
Farwell
   / Newbie with a post hole digger- tractor mounted. #6
I set many posts as well as plant trees with a post hole digger (3 point). We have sandy loam here in S.E. Michigan and I never put water in the hole as the sand is abrasive enough when dry.
What I do is run the PHD to just about the bottom of the hole, disengage the PTO and pull the PHD from the hole. The sand will stay on the flites. The I move away from the hole, engage the PTO and fling the sand off. Back up to the hole again and run in the PHD to the required depth, shut off the PTO and pull the PHD. That way, very little material falls back into the hole and you are good to go. I have done this literally hundreds of times and it always works.
   / Newbie with a post hole digger- tractor mounted. #7
<font color="blue"> A big Pain to place the cement in the hole..
</font>
Who says the post has to be in the hole when the concrete is placed. We had to set 15,000' of fence posts and all the posts were placed after the 'crete was in the hole. That was over two years ago and no sign of any weak posts.
   / Newbie with a post hole digger- tractor mounted. #8
Just my opinion from past experience..
We don't know if it is for a fence, shed, or flag pole.
I would not want to fight with a 4.5" pipe that is of any length into a hole with cement in place.
Not a lot of time to square and level.
Thin wall fence post. ok...
Just my opinion.
Doug
   / Newbie with a post hole digger- tractor mounted. #9
Another way that only works with sufficient soil moisture is to place the post, jam a rock or two in to hold it plumb, then dump concrete mix in the hole dry. In a day or two it's set up with no mixing or trying to shovel it in around the post. Some guys around here use that system for building pole barns and it seems to work.
Jim
   / Newbie with a post hole digger- tractor mounted. #10
</font><font color="blue" class="small">( I set many posts as well as plant trees with a post hole digger (3 point). We have sandy loam here in S.E. Michigan and I never put water in the hole as the sand is abrasive enough when dry.
What I do is run the PHD to just about the bottom of the hole, disengage the PTO and pull the PHD from the hole. The sand will stay on the flites. The I move away from the hole, engage the PTO and fling the sand off. Back up to the hole again and run in the PHD to the required depth, shut off the PTO and pull the PHD. That way, very little material falls back into the hole and you are good to go. I have done this literally hundreds of times and it always works. )</font>
How do you gather up the flung-off dirt for tamping?
If it's powdery dry sand it will have to be wetted to get it out of the hole.
If it's moist dirt I just carry it to the next hole on the flutes and it falls off as the next hole is dug. Then it's right there around the hole to put back in for tamping.
gabby
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
