Newbie spends quality time on OLD tractor.(long)
   / Newbie spends quality time on OLD tractor.(long) #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I was down at my cabin this weekend and my sister-in-law and her husband dropped by. They were both complaining that they were going to have to spend the afternoon bushhogging some pastures, which the both dislike, especially her. So I offered take her place and she took me up on it.
It's not like the experience was that interesting but some of you other tractor-geeks might be interested and some of my observations do tie into some 'safety' discussions that have been going on lately.
In any case, the tractor is a Case 830 Case-O-Matic. They were built in the 1960's and featured an 'automatic' transmission. It was my understanding that most farmers were leary of this fancy transmission and that they did not sell well. For some reason my B-I-L has three. Two of them are pretty much permenantly attached to two-spindle John Deere pull type 14' rotary cutters that look like heck. The other one has what looks like a homemade FEL on it with a PTO hydraulic pump to run the FEL. I have not seen it run in some time.
Here is a pic of the one my B-I-L drove, the one I drove is nearly identical:
Some info about the machine: 64 hp at the PTO. It is a 4 cyl diesel. The rear wheel (center) is cast iron and is the wheel weight. It has 8 forward gears, 2 reverse. Has typical hi/lo range lever and a 4 speed gear box plus reverse. But it also has a small lever next to the steering column. When not engaged it operates like an automatic transmission in that when you stop, you don't have to push in the clutch. When engaged it operates just like a manual transmission but when you engage it, the tractor gains a fair amount of RPM (takes off!). I don't know anything more about it but was told to keep it engaged when mowing at higher speeds and to disengage when mowing thicker stuff. To my surprise this tractor had an independant PTO. I don't know how common that is in tractors this age but it was very nice and totally independant of the clutch. However, even with the PTO disengaged it would spin a little even at idle.
Obviously, no ROPS, no seatbelt, no operator presence switch. More about that later.
Front wheels could be configured tricycle type or wide. These were set wide, almost as wide as the rears.
This tractor has a suspension seat, thank goodness, but it has a low back and was uncomfortable.
Our first job was a large hilly pasture right next to my property. I'm guessing it was at least 20 acres, could have been less or a lot more. I'm terrible at estimating. It took us 2 1/2 hours using 2 14' cutters.
We have the misfortune of being plagued with fire ants here. This field was the worst in that regard and is literally covered with dome shaped mounds.
Operating the tractor is simple enough. Much like any other. The clutch had no throw to it, maybe a 1/2 inch. More like an on/off switch. There is no 'letting out' the clutch. I don't know if it was due to wear/repair status or if it is due to the Case-O-Matic transmission. Probably the latter since the clutch is on the floor and shaped like a 'foot'. So you put the tractor in gear (5th which is 1/hi) spin the PTO up and take your foot off the clutch and it lurches forward. B-I-L says this is 'normal'. Once up to speed you engage the auto tranny lever and it lurches forward again. This is how we mowed.
Because of the ant hills the terrain is VERY rough and this machine (due to its height, which is so different from my little L4400) throws you around a lot. The suspension seat is nice but bottoms out a lot. At first the getting thrown around side to side was unnerving. But you get used to it. What I did not get used to was hitting an ant hill with the uphill tires will mowing across a hill side. These are big pastures and you have to mow across the hills. They are not steep but when that uphill front tire hits a tall, solid ant hill it really throws you around and it feels tippy. I hated that.
Once we got done with this pasture we went down the road and started a much flatter pasture with far fewer ant hills. This was quite pleasant. We mowed about an hour when his clutch went out. I continued to mow for another 30 minutes before a storm came up and we quit for the day.
I did not like driving a machine on bumpy hills without a ROPS and seatbelt. I did it, and will likely do it again many times now that my B-I-L is comfortable with me using these old tractors and large mowers. (I had driven these same tractors many years ago but not mowing. I've also driven his other JD tractors as well.) So, I'll just try and be as careful as I can. If it was my farm and my tractor, I'd try to find a way to get a ROPS and seatbelts on it. Have no idea if you can retrofit a tractor this old. Also, compared to my little tractor, the operator seat is behind the rear wheels a bit. You have to climb forward to get down. You are truly surrounded by fenders, steering wheel and levers. Jumping off of one of these would be almost impossible.
It was loud. I did not notice it at first, but when I was done my ears were ringing. My S-I-L and B-I-L wear hearing protection. The exhaust is on the front of the tractor but I think the tranny was as loud as the engine.
Which reminds me of something we were talking about in the safety forum regarding people running into things with their ROPS. I had to mow under and near a lot of trees on the pasture edges and the first thing I noticed was that the exhaust stack, and the air intake, were nearly as high as a ROPS. So for a tractor like this, the ROPS would not limit your clearance significantly more than the stack.
That's about it. We got a good bit done and my S-I-L was very pleased to have gotten out of that chore. Despite my safety misgivings I enjoyed the experience and will certainly be doing a lot more in the future. My B-I-L won't let anyone drive the hay cutter (disk type) or the bailer (and I don't want to) but I'm hoping he'll show me how to rake and ted hay (easy enough). I enjoy playing farmer and when I can do these things it is a big help to him. He helped me build my log cabin in such a way that it would have been impossible for me to do it without him so I have a debt of gratitude to pay. If I can repay him by helping him with the things he finds tedious and boring but that I enjoy, then its a perfect situation. Plus, I find driving his tractors much more fun than feeding, vacinating and worming cows, which I've done more times than I can count!
   / Newbie spends quality time on OLD tractor.(long) #2
What year model is the jeep? I like it.
   / Newbie spends quality time on OLD tractor.(long) #3
I was on an old Ford tractor a month ago and though it was kind of cool to run it, I also didn't like the lack of ROPS or how loose everthing felt on it. Sort of made me reconsider wanting to buy an old tractor to play around on. The saying about they don't make them like they used to doesn't apply to tractors. They make them allot better then they used too!!!!
I have an old jeep that I'm gonna get running one of these days. I just love the way they look when all beat up and used all the time. That one looks just about perfect!!!!!
Eddie
EddieWalker said:
I also didn't like the lack of ROPS or how loose everthing felt on it. Eddie
Loose is the word. The front tires were like shopping cart wheels! There was so much play in the steering you had to plan ahead.:D Turning the steering wheel was more like a suggestion.
Seriously though, its no wonder. Those ant hills are just torture on the tractor (not to mention the mower!)
The Jeep is an MB (?), a WWII Willys (or Ford...probably a little of both.) He has two that run and that he uses daily. One of them even has working brakes! I literally cannot count how many non running jeeps he has. And then there is the half-track. I drove it a few years ago. That same day something went south in the transmission and its been in a shed ever since.
   / Newbie spends quality time on OLD tractor.(long) #5
Great tractor story, but how about that farm jeep! I bet there are some great stories there too.
I see you have a Jeep too. I don't have any great stories about the jeeps but the two he has running get used every single day. He even uses them to round up and move the cows. I've driven them a lot for that as well since I don't ride horses (much) which he usually uses. They are fun to drive in his hilly pastures (remember the opening scene of Rat Patrol?) He has a homemade thing that fits into a box hitch receiver that allows him to haul a sick or neglected calf off the back so that the mother can see and smell it and follow along until he gets it to the barn lot.
Driving the one with no brakes takes a bit of planning ahead! You have to look for a little hill of patch of real deep grass...or just start coasting way ahead of where you need to stop.
   / Newbie spends quality time on OLD tractor.(long) #7
Afternoon George,
Very interesting post !!! I believe that I have seen that photo in one of your previous posts but nice shot just the same ! I was really hoping that you would have some new mowing pictures of you out in the fields on the old beast ;) !
When I first started mowing my property in Vt I was using my old 1942 Farmall A and an old sicklebar mower that I got in workling shape. Certainly a much smaller tractor than you were using but I didnt have any safety features on that machine and I was about to mow some fairly steep to me hills ! I went so far as to plan exactly how I was going to attack the acreage meaning what routes I would be taking with that old machine. The Farmall A is an offset as you probablly know, so I was going to mow in a counter clockwise pattern keeping the heavy side of the tractor on the upside of the hill when making my turn at the bottom of the property ! This worked out quite well and it didnt take too long before I graduated to second gear and a bit more confidence doing this chore ! :)
Getting back to your experience, and I really think you got some with getting that oppurtunity ! Your adopted tractor has a much higher seat than what your accustomed to so I could see where it could be a bit disconcerting mowing sideways and hitting one of those darn ant hills ! :eek:
Glad your OK and hope your next outing is just as good !
Scotty, I have one picture of my S-I-L on the tractor as she was coming to let me get on it (she mowed the first fence line for me). I'll try to post it when I get home.
The high seat position did make it a rougher ride. Kind of like being in the crows nest of a ship vs being on the deck. It is amazing how quickly one gets used to it though.
And after a few loops around the field I did start to alter my route a little to minimize mowing across the hill but there was one long stretch where it could not be avoided because of a fence line. (I was also trying to stay on opposite sides of the field from my B-I-L because neither of these mowers has chances or a skirt on the rear!:eek: )
I guess its just like anything else, you just have to learn how to do it, get used to the conditions and be as safe as you can. In the big flat field we did second the mowing was very pleasant. (I have noticed my S-I-L sitting crosswise in the seat, shoes off and feet resting on the fender in order to get an even tan on her legs when she is mowing one of the easier fields!)
Here is a picture of my S-I-L driving up to where she met me. My property is to my back. The area we mowed extends all the way to those two trees you see in the background on the left. The pasture extended downhill from the horizen line you see on the right. If you look closely you can see that she is barefoot and her shoes are hanging under the dash.
You might also notice that one of the front tires is a typical ribbed ag tire while the other is a military tire off of an old jeep.
   / Newbie spends quality time on OLD tractor.(long) #10
Hey George. Sounds like it was a good experience. I love that first picture you posted. From the little bit of smoke (coming from the Jeep I guess) to the fact that the tractor looks like it was left in the middle of nowhere! It appears to be getting jump started and so that would make you think it's been where it is for at least a little while.... so you think it'd be up against a barn, under a shed, something... and the pic makes it look like it's just out in a field somewhere! :) There is probably a barn or something nearby that you can't see... I just thought it looked funny!
Have a good one.
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
