CPTP
Greetings,
This is my first post so I apologize if this has been addressed in prior forum posts, but I didn稚 find anything in the search to address my issue.
I am the owner of a YM1610 with a front end loader. I purchased this tractor in conjunction with my house and land ~5.5 acres in late 2010. It seemed to run fine until it suddenly broke the weld on the neck of the radiator. I had the neck re-welded reinstalled and then the tractor sat for a year while I was on deployment all of 2011. In spring of 2012 I started the tractor up and did some land clearing. It worked for about 2 days of light clearing (1-2 hours each day) but on the 3rd day my repaired radiator again broke its weld at the top. I ordered a new radiator and had a mechanic come to do a once over. He changed out all the fluids and installed my new radiator. We started her up but there were bubbles coming from out of the radiator into the reservoir. The mechanic said that this was due to a blown head gasket and he didn稚 have the expertise to deal with that (he was more of a mower/lawn tractor mechanic). I searched in vain for another tractor mechanic but was deployed again soon after and haven稚 had the time to invest until recently. So, considering this has sat for a year since having its fluids changed out, I have the following questions:
-Is a blown head gasket what is causing my overheating/overpressure problems?
-Is this something I can fix myself? I am fairly good with tools, mechanical systems, and can follow directions like a champ.
-Is this something that could lead to more problems? E.g. taking the head off, see X needs to be changed/replaced, leading to X needing to be changed, and down the rabbit hole we go. I understand that some of that is inevitable this being an old tractor, just that if the head gasket change out is my level but the follow-on is not, I am worse off than when I started.
-If this seems like something beyond my level (or available time) is there anyone that the group recommends for service/repair in my area (Fayetteville, NC)?
- What other delights can I expect to find with a tractor that has sat this long (exposed - I know i'm a horrible person).
Thanks. I appreciate any information.
