Grading Newbie question
   / Newbie question #1
Usmcsrt1
Graniteville, SC
2016 Mahindra 2555 HST
When I'm box blading and have the 6 spikes digging into the ground a few inches and I hit a buried stump or something else tough, do I need to worry about any of the 3 .pt hookups on the rear of the tractor breaking or bending? Is there a factory default with the tractor or the boxblade that will give first? 2555HST. Thanks!
   / Newbie question #2
Impossible to say.
However, when pulling with the rippers down 3" to 4" in the soil you will be moving slowly.
Most Box Blade 'points' are crimp on. I have had two pop off over the years. Crimp on 'points' are one fail safe opportunity.
I use a Hydraulink Top Link when operating my Box Blade and several other implements. Before buying my Kubota L3560, I used the Hydraulink Top Link on my light 'B' series Kubota B3300SU. Besides making Top Link adjustment easier, the Hydraulink is a great shock absorber. I believe Hydraulink preserves welds on both tractors and implements. This may be your $250 answer. (Sold on eBay, Amazon and by your local Agri Supply)
VIDEO: HydrauLink Category 1 Cylinder - For 45 HP Tractors or Less, Model# HL-11 - YouTube
PHOTO: B3300SU/HydrauLink/Bush Hog (brand) 60" Rollover Box Blade.
   / Newbie question
I just checked it out. Pretty interesting. Think I need one. Thanks!
   / Newbie question #4
With HST I would thing you would come to a dead stop before breaking anything.I have stopped my 7,000 lbs tractor without breaking anything.
   / Newbie question #5
I would watch out for the stumps and not hit them.
   / Newbie question #6
That link sure is an expensive shock absorber. :eek: Why is it always shown on a small tractor with someone reaching over the back to adjust it? I can't get anywhere near my top link from the seat. I guess it's just for small tractors then?
   / Newbie question #7
HydrauLink is made in Category 1 and Category 2 Top Link sizes.
   / Newbie question #8
Impossible to say.
First I have seen one of these. Makes really good sense in my mind. Kind of expensive, but definitely on my wish list - Thanks for sharing!
Usmcsrt1 - As to the box blade hitting things, I have been known to grab roots and stumps with the Max 24 that used to run a 4' box blade. That thing would stop dead and spin. OR - once while looking back and boxblading in reverse, I hit a stump unexpectedly and it stopped so fast that I smashed my eye socket into the ROPS and ended up with 11 stitches just below my eyebrow. Dr and nurses did not believe my story... :eek:
With my heavier 2538 or your big 2555 I can see how a lot more force would be imparted to the implement and the tractor, but like Jeff noted, when you're ripping with all teeth down I assume you are moving relatively slow and I doubt anything catastrophic happens unless you do this chronically.
   / Newbie question
Thanks guys. I proceeded extremely slow and didn't have any issues.
2020 JOHN DEERE 3032E TRACTOR LOADER BACKHOE (A51243)
2020 JOHN DEERE...
2014 Dodge Charger (A50324)
2014 Dodge Charger...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
