Newbie Question? starting / running / shutting off
   / Newbie Question? starting / running / shutting off #1
cam0148
Penticton, BC Canada
Cub Cadet EX3200
As a newbie to my own yanmar tractor I have a couple questions about starting / running / shutting off a diesel tractor.
I have a 1500d
1. Does the tractor need to warm up before I start to use it? (no glow plugs)
2. Is it OK to start a tractor then shut if off shortly after? (eg. 1 minute later
3. After running the tractor for a while should you let the enging idle at a low rpm for a while before shutting it off?
Thanks,
Jeff
   / Newbie Question? starting / running / shutting off #2
Here's what I recommend and have read that you do.
<font color="blue">1. Does the tractor need to warm up before I start to use it? (no glow plugs)</font>
Yes, I always let mine warm a bit at a high idle at the first start of the day. I don't go overboard with it, because an engine will warm quicker when working than idling, just enough to ensure good air/fuel mixing.
<font color="blue">2. Is it OK to start a tractor then shut if off shortly after? (eg. 1 minute later)</font>
I've always been told that it's bad for a diesel engine, and a gas too I would think, to start it and shut it right back down especially if you do it a few times in succession. See the above quote, Once it's warmed I don't see any prob with shutting it down to hook up implements and such.
<font color="blue">3. After running the tractor for a while should you let the enging idle at a low rpm for a while before shutting it off?</font>
I don't know if it makes a huge difference and all my manual says is to pull the throttle all the way to low idle and shut off the engine, but I always let mine idle for several seconds before shutting it off. My lawn mower manual says to idle it for a short period before shutting it down.
   / Newbie Question? starting / running / shutting off #3
You asked if you should let it idle for a while before shutting it down. Well, from all I have read on here, you should let it idle for a few minutes to let it cool down some, before you shut it off. That it does do it some harm if shut off without doing that. I only let it idle for two or three minutes, but then I have let it idle down while backing it into my garage to though, which makes for another couple of minutes or so.
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator (A51573)
2025 New/Unused...
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Service Truck (A51692)
2019 Dodge Ram...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
