newbie question...greasing
   / newbie question...greasing #1
WiJC
Wisconsin
kubota B7610
ok...so now i have a pretty orange tractor sitting in my garage...and that leads me to a newbie question...
greasing...how often? what kind of grease is best to use? where is the best place to buy it?
there are maybe half a dozen spots on the tractor, and a bunch more on the loader.
i went to the local fleetfarm and they had about 7-8 different kinds of grease???
thanks
John
   / newbie question...greasing #2
I like boat trailer wheel bearing grease because it is the most durable in my opinion, but like all opinions, there are going to be as many different ones here as there are people.
   / newbie question...greasing #3
WiJC I think the FEL and the BH is every 10 hours of use. I grease the tractor at the same time, grease is cheaper than parts, I like the White Lithium, don't know why, looks cleaner I guess.
   / newbie question...greasing #4
I use the super secret formula Kubota grease that is bluish-greenish. It is for greasing the zerks on your tractor, works very well, is water resistant and does not clash with the orange paint. It costs about $2.50 a tube and you may need 2 to 3 tubes a year.
   / newbie question...greasing #5
Hmmm...I'm going on memory, but it seems to me that the Kubota manual says to use general purpose grease for the tractor and high pressure grease for the loader. In any event, I know I used it as an excuse to buy an extra grease gun and have two types loaded up /forums/images/graemlins/grin.gif
Kevin
   / newbie question...greasing #6
I don't know about any of that. I just grease it with the top secret formula stuff. There are only 5 zerks on my L3830, four of which are analogus to the loader as they use pins just like the loader. Those are located on the 3 pt hitch arms. The only other one is on the front pivot of the axle. The loader has it's usual cadre of joints that get loaded with grease far more frequently then the tractor ones. I've experimeted with a few greases like Amsoil, Mobil, etc., now I just pick up 4 tubes with each oil filter and I'm set for some time. Let's see 4 tubes of secret greenish bluish was $12 and the oil filter was $6.50. Who said the Kubota stuff was pricey? /forums/images/graemlins/wink.gif
   / newbie question...greasing #7
My friend's a mechanical engineer and he's helped me understand about greases, gears and all kinds of mechanical things over the years so here's my version of his 2 cents. His mantra is "any grease is better than no grease", so it's probably not so important what kind of grease you use for plain bearing applications and sliding elements like tractors use.
Seals which have been exposed to one type of grease can degrade if you're unlucky when you pick a different kind (not brand, a different type) of grease with conflicting chemistry. So don't switch greases once you pick one. Clean the fitting first and flush all the old grease out each time you grease. When grease oxidizes from heat, or becomes contaminated with moisture, rust or corrosives, it needs to be purged. Similarly if it exceeds it's drop point, the temperature at which the base melts, it does not return to it's original composition and needs to be removed. Alternate implement positions each time you grease, ie roll the bucket forward one time, backward the next.
Multipurpose greases are generally the best if you're positive that the lowest drop point of all the components is not below the service temperature. White lithium grease is supposed to be a very good grease with wide operating temperatures but I was only successful finding a data sheet on the product made by caterpiller, something that isn't available in stores. Without knowing the recommended temperature range it's kind of flying blind.
Special purpose greases are required for certain applications, like high pressure greases on gears and plain bearing applications on tractor loaders. These have lower temperature operating ranges, but the grease has to sustain much higher shear forces.
It feels like they're using the lubricant on me when I have to pay those high manufacturer prices, but they also paid someone to figure out which kind of grease to use in the first place so I just try to remind myself I'm creating jobs.
   / newbie question...greasing #8
John:
If you went to the farm store, the grease would probably be bewildering to you.
We use about 5 different types of grease from lithium disulfide to teflon based grease depending on the application, type of implement and intended use. There are even food grade greases for use on equipment that comes in contact with edible foodstuffs.
For the average CUT owner, I'd recommend the applicable factory brand grease like RaT uses. I'm sure that Kubota, Kioti, JD and others have tested their grease's and found them to be satisfactory for their equipment.
   / newbie question...greasing #9
i would just say to use a good quality general pupose grease, greas often and purge the old grease out. actually my tractor b2400 only has 1 grease fitting for the tractor all the rest are on the fel. and other attachements. this may be over doing it but i like to grease everything , then put the fel in a different position and hit it with another shot of grease.
   / newbie question...greasing #10
I usually grease everything too; including myself. Alls I have to do is get within 10 feet of a grease gun and it jumps out and all over me.
Egon
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
