Newbie question - 05 John Deere 4520 Misfiring
   / Newbie question - 05 John Deere 4520 Misfiring #1
GM9
Virginia
2005 John Deere 4520, 2013 John Deere 5101E, 90's John Deere 5300
Hello. I am new to the forum. I searched and can't seem to find an answer. (Not sure how to search for an 05 4520. Is it 4520, 4X20, 4xxx, 4000 series, etc? Then there is the 70's vintage 4520)
Anyway, I've owned a 2005 4520 for a few years now. For the past while, it misfires when accelerating. Like one or two cylenders not firing. It seems to be getting worse, almost to the point of shutting off. A freind mentioned something about his Kubota having air in the fuel lines(?). Does that make sense? Any help will be appreciated.
Oh yeah, in addition, I am getting an intermittent error code 74, but not sure that is relavent.
   / Newbie question - 05 John Deere 4520 Misfiring #3
Can't help you with the error code, but it sounds like you have at least one bad injector.
   / Newbie question - 05 John Deere 4520 Misfiring #4
You should have a listing for a number of the more common error codes in the back of your Owner's Manual. Does sound like a bad injector or two. Have you noticed any change in the crankcase oil? Like over full? Or excessively black - pretty quickly after an oil/filter change? Any diesel fuel smell to the oil?
Injectors that are sticking will tend to load up the engine crankcase with unburned fuel.. That's not a positive situation!
AKfish
   / Newbie question - 05 John Deere 4520 Misfiring #5
According to my service manual ERR_74 is the display mode switch is stuck on....Doesn't sound related to your problem, but you never know..
   / Newbie question - 05 John Deere 4520 Misfiring #6
Do you have access to a thermos temp gun? if so measure the exhaust temp manifold . the cyl. (cyls) causing the misfiring can lead you toward problem
Next is it a single cyl or more than one,
constant or random maybe check for fuel sys problem injector or pump.
This also could be head gasket failure. so check compression. low cyl valve or ring .
What does the turbo sound like when this is happening . squealing or loss of pressure.
Wish could help more just need more information.
ken
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2016 Ford F-450 Ext. Cab Knapheide Stakebody Flatbed Truck (A50323)
2016 Ford F-450...
2016 Gooseneck 32' Livestock Trailer (A50121)
2016 Gooseneck 32'...
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
2023 John Deere Z994R (A50121)
2023 John Deere...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
