Spreader Newbie needs to know question about manure spreader
   / Newbie needs to know question about manure spreader #1
vainva
Kabota L2400 45 HP
I bought an older manure spreader, no name, id or otherwise, has rubber tires, not metal wheels. It is ground driven and looks like several I have seen over the years. It looks alot like the CDT McCormik 100, but not exactly. Size and levers match up, but it is not the same. Finally hooked it up and the chains that run the screw type blades and toothy things work fine. The chain that drives the angle iron to move the material to the blades does not move. I can't figure out where the gear to move that chain is. Is there something internal with the axle? I have been looking on line for manuals or basic pictures of the drive mechanisms. I can attach pictures tomorrow as it is dark now and I have given up for the day.
   / Newbie needs to know question about manure spreader #2
If the beaters are working, sounds like the main drive chain is there. Sounds like a shorter chain is missing to drive the apron ratchet mechanism, OR..., the ratchet mechanism may not be catching, or broken/worn. Could be as simple as the spring is broken, to pull the dog in, to engage the ratchet gear.
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
Chain Link Fence (A51573)
Chain Link Fence...
2014 CASE 586H FORKLIFT (A52576)
2014 CASE 586H...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
