newbie need opinion
   / newbie need opinion #1
towoc999
Qu饕ec Canada
Hi !
I'm in the process of buying :
Bx25 or BX24 seems that all posts they are pretty much the same machine,
price wise seems almost the same also , I can get used BX24 bu I might want a bit more relief with the zero % interest on the purchase of the new machine and also the waranty .
The only issue I'm not sure is that I read that the BX25 does not come with the 3 points hitch attachement bars , am I right ?
thank's
that is a great forum !!!
   / newbie need opinion #2
They are an extra cost option on the BX25, I believe. Your dealer should be able to tell you for sure.
   / newbie need opinion #3
...The only issue I'm not sure is that I read that the BX25 does not come with the 3 points hitch attachement bars , am I right ?...
Towoc, you are correct. However, there does seem to be some confusion over the price. In an ealier post, Petethenomad said that his dealer was asking $500 for the 3 point hitch kit for his new BX25. Yesterday, I contacted a dealer in NY State who said that he would sell that kit for $200. It is wise to shop around.
   / newbie need opinion #4
I'd let other considerations drive your decision between the BX24 and BX25. There are benefits to the BX25, but only you can decide if they're worth $2,000 to you.
I would not consider NOT purchasing the 3PH kit for the BX25. Even if you don't think you'll use it, you don't want to NOT have it if for no other reason than to maximize your resale 32 years from now.
Be it $200 or $500, it is not the dealbreaker in your $15k to $17k purchase.
There are other posts regarding BX24 vs. 25 in this forum...recent ones. Poke around then sit on them at your dealership. Can't go wrong either way.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2013 Acura ILX Hybrid Sedan (A50324)
2013 Acura ILX...
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
