Newbie looking at small dozer
   / Newbie looking at small dozer #1
Crawlake
Saskatchewan
Caterpillar 232 skid steer
Hi there,
I've been looking at a komatsu d21p-6. I have found one with the rubber tracks. I have lots of small trees and willows to clear, and some of it is in some low, soft ground. I am wondering how the rubber tracks will stand up to this type of work?
   / Newbie looking at small dozer #2
Welcome.......the rubber tracks should be fine......my buddy has used them on his Bobcat for years.....:2cents:
   / Newbie looking at small dozer #3
I think rubber tracks would be fine for your use, especially in soft ground. Long as your not using it in rocks, they are hard on rubber tracks. Show pics of your work, I am interested in a d 21 myself. LUTT
   / Newbie looking at small dozer #4
Crushed, blasted, and fractured ledge are hard on rubber anything. From tires to tracks. Steel tracks wear and are very expensive to replace. Rubber tracks are also much easier to get back on if you have one come off. Steel is an accident waiting to happen. Anything that weighs that much is just hard to work with. The pads open up more than wide enough for fingers to get caught between when trying to move the track into position to get it back onto the dozer.
   / Newbie looking at small dozer #5
If your work will mostly be in really soft ground I'd probably hold out for a "p" model with the wide pyramid tracks. My d20 p6 is nearly impossible to stick (I did manage to once trying to backdrag in bottomless wet slop). The rubber tracks would probably be fine for most general work though. They are good little dozers, easy to work on too. Hope you find just what you need in your search!
   / Newbie looking at small dozer #6
Rubber tracks should be fine. I have a larger Komatsu dozer and it's been a great machine.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A52377)
2006 Crimson...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
