Hi all.
This is my first post here. I have have a new kubota BX2670 and a couple of attachments. FEL, 54 MMM with mulch kit, block heater, and a Landpride 5 ft rear blade.
After reading my manuals and scouring youtube, forums and mr google I am still left with a couple of questions. I have never had a "Tractor" before moving to this property.
So naturally I came here
I have 2 acre property all cleared and all able to be mowed. My drive way is a combination of pavers and ashpalt (20 x 75 ish) I also have a simplicity regent lawn tractor that I use for mowing too.
I replaced my steal blade with a Ultra high molecular weight plastic (UHMW) construction (plastic blade used on ATV's) as to prevent scraping on my driveway and plan on getting rollers for the back from big league lawns for striping.
Well thats about it for me so my questions.
1. I have learned about the float position for the FEL and tried it out on the roadway. However, I have only seen it used in videos on flat ground. My driveway has about 15% slope. Before I gave it a go Would it still work fine? My thoughts are that I would only have to worry about the angle of the blade so as to not tear up the driveway with it in float position. If I keep it slightly up, it should follow the slope, no?
2. The rear blade. I replaced my steal blade with a Ultra high molecular weight plastic (UHMW) construction (plastic blade used on ATV's) as to prevent scraping and tearing up my driveway. I plan to have it angled off to the side and have a place to dump the snow with the FEL if needed. I'm a bit confused as to if I should have my blade facing backwards as I have seen in a few videos (tractor still going forward)? I also am not sure what angle the blade should be at. i.e.., the top part of the 3ph bar? Should it be angled forward, back, upright etc?
3. Mower deck. I still need to go get the JD measureing tape I have seen on here to make sure it is set up right. However, my anti scalp wheels are always on the ground when set according to the manual. Ie., I have the dial set to 3 inch so I have the wheels at position C. The problem I see is that my anti scalp wheels are rolling on the lawn all the time. I'm not sure why this is. The manual says that there should be about 6mm-13mm clearance. When I put the mower down I put the hydraulic control leaver all the way down. Am I supposed to use that to keep it just off the ground? I thought for some reason that when I put it all the way down that the deck would still be suspended since I have it set to 3 inch.
Not sure if I explained things well as this is all new to me. Looking forward to your help along the way
